RCU Forums - View Single Post - 75 ax
Thread: 75 ax
Old 04-17-2009 | 07:10 PM
HighPlains
Default RE: 75 ax
You can get a sense of how hot the engine is running during break-in by feeling the exhaust stream an inch or two behind the muffler outlet. The fingers get a bit oily but it won't burn them to take a quick feel.
Generally, use the lightest prop (lowest pitch and diameter) recommended by the engine manufacturer for break-in. Most ABC/ABN engines need only a tank or two before flying.
