RE: Hangar 9 Tango rudder
Sufficient exponential function helps with the rudder on this plane. And yes, it will roll with just the rudder alone due to the coupling. Torque steer is a lot more pronounced, even more so than the Seagull Decathlon. So you have to use more finese on takeoffs. Obviously, the controls are highly sensitive and reactive, and you have to get used to them. Once the Tango is mastered, it can be very rewarding.
NorfolkSouthern
