RE: DONE with the JR 9303
Can you explain a little more . Do I have this correct ? You wish to mix two separate channels togehter and have the trim input go to both ?
My JR 8103 does this now. I use mixing on my dual servo elevators and my alerons and the trim inputs go to both.
Do you wish to mix 4 channels together? One for each control surface on your bipe?)
Will Y connectors fed into 2 channels , mixed not do it?
Allan
