RCU Forums - View Single Post - gyro question
Old 04-19-2009 | 05:36 AM
David Gladwin's Avatar
David Gladwin
Default RE: gyro question
Sorry Delgato you really have it all mixed up. I have been using ailerons on real and model jets on approach (somtimes in 35 knots of crosswind, in Boeings, no problem ! ) A gyro does it automatically on models , makes the approach smoother. HOWEVER, if you fly the approach very near or at the stall, which is a very unwise thing to do with ANY aeroplane, large or small, you CAN make a wing drop worse by using aileron, Thats why, one reason anyway, we keep a sensible margin ABOVE the stall on the approach. I have just spent a week demonstrating that to Air Cadets in gliders by showing them the result of coarse use of aileron AT the stall: incipient spin, and INSISTING they fly at a safe margin above the stall.
Remember too that ailerons controlled by gyros have limited authority otherwise they "hunt".
No, just add a gyro to aileron and rudder if neccesary and see how much smoother they make things, I doubt I will ever equip another jet without an aileron gyro.
...and PS please don't tell my Hawks about the need for a gyro on rudder, they go straight on t/o without one, ( so does my Starjet and L39 and my Mig 29) although I do give them a little help with rudder and nosweheel steering ! Actually on my BobCats the gyro gain is INCREASED with gear down ! You must also remember that any yaw caused by aileron application is immediately countered by the gyro on the rudder if you are using one.
Its also worth remembering that if a heavily loaded model requires high speed for take off the rudder authority will increase as the SQUARE of the speed which should make it more directionally stable and controllable.
I have four jets with aileron gyros, two Bobcats (which also have rudder gyros) and two Air World Hawks, (aileron ONLY) the result is really smooth flying although to retain normal aileron sensitivity you do have to increase aileron travel by an amount equal to the gyro travel authority UNLESS you have stick priority.
We did quite an extensive article in RCJI about 18 months ago on gyro theory and practice, its all there !
Here a picture of a gyro in action!
Regards,
David.
