RE: Using a "TopFlite" Prop Balancer
The photo on the left is the recommended setup. I've experienced the same thing, cones touching and not holding the prop snugly, with some props.
I've never heard of a 'non precision' hole. APC and Master Airscrew have a stepped hole. The center hole is usually 1/4 and the bigger hole is usually 5/16 since these are very common shaft sizes for many popular glow engines.
I do not balance props unless I install one and have a vibration.
