RCU Forums - View Single Post - SEQUEL, Laser cut kit
Old 04-19-2009 | 02:29 PM
Pattern One's Avatar
Pattern One
My Feedback: (73)
Default RE: SEQUEL, Laser cut kit
Hello,
The Majority of the Stab has been completed. The top and bottom spars have been added, the leading edges have been glued on. The end ribs have been sanded flat to accept the stab tips when it's time. The LE & TE need to be sanded to rib shape. The rib ends and rib end trailing edge need to be added behind the TE that you see now prior to sheeting. More on that in the next post or two. I can't wait to get it sheeted and cut the center section loose so the Flying Stab moves! Dan at Laser Technologies has done a fantastic job on this.
Leo
ID:	1183369   Click image for larger version
ID:	1183370   Click image for larger version
ID:	1183371   Click image for larger version
ID:	1183372   Click image for larger version
ID:	1183373   Click image for larger version
