RE: Carden 37.5% Yak Build
Here are a few more shots of Dan Woods airplane. Its getting very close for Monokote. The egine box bottom still needs to be installed around the pipe tunnel. Mine has been delayed a few weeks so I could get my Edge out of the shop this month and also so Dan can have his Yak for the Joe Nall. Dans is set up with a DA 150 on greeves pipe. My yak will be back on the bench in a couple of weeks and more pics will follow on its progress. I'll keep following Dans all the way to the end as well. You can see Dan sprung for the milled gear and is running the Robart p-51 wheels that are very cool looking but add a little weight. They will look nice with the custom wheel spats Eric is making for both Yaks. I will be using the white rose wheels on mine for bling and light weight.
