ORIGINAL: for_xakep
I got my F/A-18C ver.2. It’s my first plane and I have to admit it was clear instructions and easy to build, but
Power up receiver and plane, plane respond on all command, when I do 10 steps away it losing control – all servos moves and motor powers up. If I’m getting closer to plane or it moving my direction it getting in sync and getting under control.
Please, respond if someone had similar situation or know what can it be.
Since this is your first plane, then let me hit you with a question that may seem a bit basic...
Did you unravel the antenna which comes packed inside the fuse and bring out outside the fuse, then tape ( I use hot glue ) it to the outside of the plane?
