RCU Forums - View Single Post - hooker on arrow shark hull.
Old 04-20-2009 | 12:33 AM
wet a wild
Default hooker on arrow shark hull.
i am aware that some hulls is made with a hooker at the transom to keep the nose down. i am busy building a dragon fly from arrow shark but are concern about the huge hooker on this small hull[X(] if you take a straight edge from the transom to the nose you will have a 2mm hooker[:-] 1" from the transom both sides. what will happen if i fill this up and level the hull. i can still use the trim tabs for setting up the hull.
