Irvine .53 problem
You can fill the cylinder with fuel if you let it flood when trying to start by improper fuel tank location, a bad glow plug or wrong needle valve setting. If you use a starter whern the cylinder is full the fuel will not compress and needs somewhere to go. This can bend conn rod, break stuff, etc.
Search RCU and you wil find more info.
PT
