RCU Forums - View Single Post - How to setup a DX7i on a BLADE400.
Old 04-20-2009 | 06:05 AM
old school racing
Default RE: How to setup a DX7i on a BLADE400.
My swash mix is Aile -75 Elev +75 Pit. +85. 3 servos 120 degrees, exp inh and channel 2& 4 are reversed. Would it make sense to change the swash mix values. The rudder control is good ,I pulled the reciever out again to verify that all servos where plugged in according to the setup on this page. I have spooled the heli up and at half stick the swash plate is level, but at full throttle the swash plate pitches forward . shouldn't the swash plate just go down when you come up to full throttle and the opposite when pull the stick back. I thought I had two servos plugged in wrong but that wasn't the case. I somtimes wished I never changed radios. I tried reversing the throttle servo but the radio or heli just beeps and does nothing . Thats why I can't figure this out the throttle works as far as spooling it up but the swash plate isn't or doesn't appear to be right in its movement.
