ORIGINAL: rgm762
what our club found out through trail and error, alot of errors
, is in order to use th dxi6 you have to use another computer radio, and both tx's MUST be set identical, i.e. epa, expo, servo reverse, mixing and so on, IF just one setting is different, then it won't work
I was easily able to use a DX5 (not a computer TX) as a slave to the DX6i. Worked like a charm!
