RE: end point adj.
The radio has two small pots marked “end point adjustment throttle” one marked high and one low, each one moves the servo a several degrees. With the throttle at max the high adj. and the trim moves the servo. The push rod bends in both directions because the rod is not straight but has a bend in it. Were do I set the trim during the high and low adjustment?
