RE: end point adj.
The trim should not affect the high end - That is, when the throttle stick is wide open, the trim should have no effect.
On the low end, the trim should should be set so that when it is all the way down the barrel should be completely closed and when it's all the way up, you should see a fairly good size opening (As idles go).
