RE: end point adj.
On some transmitters, the trim does effect the high end as well as the low end. To be safe, set the trim to max then set the high end point so it just moves the throttle to the stop (no bend in push/pull rod). Then set trim to min and set the low end of the EPA so that the throttle barrel just barely completely closes.
