Wing Span
Right Now it has a 52 inch wing span. I can make it a little longer if needed. Also what size fule tank are you using. People have stated "whatever size tank you need to get 6+ minutes of full throttle flingt" Will four ouncse work or does it have to be a 6 ounce tank. I currently fly a OS MAX .28 ABC engine and 6 ounces of fuel is more then enough.
John Boren
