RCU Forums - View Single Post - crank taper
Thread: crank taper
Old 04-20-2009 | 04:42 PM
captinjohn
Default RE: crank taper
If the flywheel has the correct taper as the shaft...it will...and should stay in place without the nut. A little locktie will hold it there in place for the correct timing also. No key is needed. Yup....thtas is a way to advance the timing on a flywheel ignition engine! Capt,n
