ORIGINAL: blu0val
Anyone still monitoring this forum? Just installed the reverse module in my Savage X. It went in smooth and there weren't any problems, until I tested it...it works fine for a couple of uses and then the linkage slips off the module lever. I reinstalled the linkage and it keeps happening. was thinking of just twisting some wire or something around the linkage to keep it together, but what is the real problem here? It slips off right at the bend in the linkage. Any help? Thanks
The bend in the wire should be on the servo horn, not the module lever... on the lever you should have a little collar with a setscrew, then some fuel tubing, then the module lever, more tubing, then another collar....
