RCU Forums - View Single Post - Low Idle Adjustment
Old 06-17-2003 | 01:55 PM
MinnFlyer's Avatar
MinnFlyer
Default Low Idle Adjustment
On the side of the carb, opposite the needle valve (in the center of the throttle control) is a small set screw. Turn it clockwise to lean, and CCW to richen,
Also, if you can shift some weight forward, or add nose weight, she won't snap so badly.
