RCU Forums - View Single Post - X-treme Composite Altair 200
Old 04-21-2009 | 02:50 AM
riot3d
Default RE: X-treme Composite Altair 200
I finally found some time to start installing the engine. First, two holes has to be cut on the firewall. One for the spark plug cable, the other for the timing sensor wire. Be sure to insert rubber grommet onto the firewall to prevent the spark plug cable from chaffing.
The next step is to install a honeycomb platform for the cdi unit, all real straight forward. Next is to install plumbing, throttle servo/ push rod, header and pipe. Hopefully, will get that taking care of in the next two evenings.
ID:	1184470   Click image for larger version
ID:	1184471   Click image for larger version
ID:	1184472   Click image for larger version
ID:	1184473   Click image for larger version
ID:	1184474   Click image for larger version
ID:	1184475   Click image for larger version
ID:	1184476   Click image for larger version
ID:	1184478   Click image for larger version
ID:	1184479   Click image for larger version
ID:	1184480   Click image for larger version
