RCU Forums - View Single Post - Ignition failure
Old 04-21-2009 | 10:11 AM
DadsToysBG
My Feedback: (35)
Default RE: Ignition failure
The real answer to your question is in your own words "cheap". That word could have cost you a plane if it had failed in the air. The new CDI will tell you what voltage to use and if you insist on li-po's then use a good voltage regulator. Some of the new CDI can use 7.2. Older versions are 4.8 only. Dennis
