RE: Official HPI MT2 Thread
eminent what gears do you still need?
hpidude the trucks are doing well. The weather finally started to warm up here so Ive been able to run them a few times this month. Im going to be putting the 2 speed back into the MT2 with the TZ soon. I cant wait to see how that works.
The 18ss+ and the G3.0 are basically the same truck. One was a kit the other RTR. All the parts will work together. The 18ss+ had better diffs then the RTR's so they should hold up just fine. Im not sure on the power of the G3.0 compared to the 18SS. I think the 18SS engine was supposed to be "outlaw" class that should give it a bit more power. To load images you need to click "post reply" and not use the quick reply box at the bottom. The "post reply" will give you an option to upload images.
wil, what screws are coming loose on you? If the metal screws are coming out of the plastic then the plastic is stripped so changing the screws wont make a difference. Check out SMFstore.com they have a lot of screw kits available too.
Ill get some update pictures posted later today of both of my MT2's
