RCU Forums - View Single Post - roll & turn
Thread: roll & turn
Old 04-21-2009 | 03:02 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: roll & turn
You are flying a sim, not a real plane, so try different things and see what happens. Try initiating with the rudder then using ailerons and elevator, try the opposite, and pay attention to what happens.
I don't really think about what I do anymore, it just kind of happens. If I had to guess I'd say I start all 3 at the same time.
Try using too much rudder, using no rudder, using a little rudder, etc.
Try making tuns without using the ailerons on a plane with dihedral.
Eventually you will find what you think works the best or looks the best, for you.
The 'real' airplanes I've flown have a little 'coordination bubble' on the control panel. If you roll the plane it will go off center if you don't also use rudder. I didn't really stare at the thing, but being as it's based on a bubble floating in a liquid, I would guess that it 'wants' to have rudder input as soon as there is aileron input; easing into both controls of course.
