Composite Roo
Ive just set up the wings on my Roo, I had a little alignment problem with the retaining bolt on one wing but fixed it by enlarging the hole slightly in the wing.
The problem is with the wings on and the bolt tightened just snug, how much movement of the vertical fins is allowable ?
Some amount of lateral movement is possible when the top of the fin is moved ,it is not absolutely rigid, Is this normal ??
Also what is the ideal location for the elevon servo wires to exit from the wings into the fuse.
Where should one drill holes for the wires to exit.
Nandan
