RE: DX7 settings for CPP2 questions.
I've just got to ask what may be an obvious question. But it appears you have reversed the opposite channels that I've reversed. Also, you have negative servo mix where mine are positive (I reverse 2,4 which are AIL, PIT). Ok, but they both work so I have to assume that both settings are ok. At least up to a point.
Because I don't understand the difference (and because my LHS guru setup my Normal/Reverse settings for me before I started altering Swash Mix), could you tell me if there is any compelling reason to use one method over the other?
I think I'll setup a new model and use your settings and see how they affect the flight.
