RE: Arming motor using transmitter
Mike, what transmitter do you have?
I have an Optic 6 and it has a "Throttle Cut" momentary push button switch on top which is only temporary, but there's a "Lock" button down next to the display which will lock the throttle where it is at the time the button is pushed (which I do with the throttle all the way off). This prevents the motor from running until I push it again.
Bill
