RCU Forums - View Single Post - Top Flite Staggerwing
Old 04-22-2009 | 04:30 PM
  #1177
F82FAN's Avatar
F82FAN
My Feedback: (10)
Default RE: Top Flite Staggerwing
ORIGINAL: knucklebutt
O.K. gang heres the photo of the tail wheel pull pull issue. The arrow points to the tube that should have been about 3/4"further left. When the Robart tail wheel unit is installed it will totally block this tube. If you look you can see where the protruding piece has been broken off by the installation of the tail wheel unit. Blue circle indicates where the tube needs to exit. I am fixing this as we speak and will post the fix as well as tools needed (if it works)
Denis
Hi Denis,
We just dis-lodged that tube from the support and, when the pull-pull system is tightened up, the tube will "float" while protecting things from rubbing. Not much "fixing" really necessary (Unless you are from Texas...)
