RE: Super confused, dont want to burn something out
Hi,
The Ignition Cutoff is not suppose to be hooked up to the board. You have to have three (3) batteries, two for the PowerSystem Sport Plus and one for the ignition. The Ignition Cutoff is hooked up as follows:
Ignition Battery -> Ignition Switch (Cermark) -> Ignition Cutoff Rx -> Engine Ignition.
The fiber-optic cable connects the fiber-optic transmitter on the PowerSystem Sport Plus to the Ignition Cutoff Rx on the ignition.
You hook each of your system batteries to a switch (Cermark) and then into the two "B" ports on the PowerSystem Sport Plus.
If this is still confusing maybe it would be best to call us.
