conversion of trainer to taildragger?
My setup was a little different. A cheapo tailwheel mount which was mounted fon the bottom of the fuse with the swivel point in line with the rudder. Then I ran the tailwheel wire straight up through the fuse to the rudder - where I applied some pliers to put a bend in it. THEN I 'sewed' the wire to the rudder itself.........all done.
