RCU Forums - View Single Post - Y-lead
Thread: Y-lead
Old 04-23-2009 | 07:32 AM
Korps's Avatar
Korps
Default RE: Y-lead
I only have one port on the receiver for ailerons (if that is what you are referring too). Basically the setup I have at the moment is where I have the Y-lead/harness connected too my receiver. I need too take off my wings for transportation. So when I get too the field I slip on the wings and just connect the lead coming from the servo on the Y-lead/harness.
Is it the servo reverser which makes that the servos operate correctly when using that lead? Like I said the reason I'm asking this is because - when I use the "reverser one" the ailerons work as they should, but when I use the one which the want me too use both ailerons either go down or up.
