RCU Forums - View Single Post - Help! Which RTF to get?
Old 04-23-2009 | 08:04 AM
mickvk
Default RE: Help! Which RTF to get?
The Wilga 2000 from BananaHobby is made-in-China junk. Worse than bad instructions - flat out incomplete. Terrible kit quality - the radio was set up not for US standard. Documentation was unclear. No documentation on ESC programming mode at all. Control surfaces are terrible... Rudder push rod bends instead of moving the rudder. The ailerons flex and are sloppy with poor masking tape hinges. The prop mount is prone to failure. Wing mounts are not durable.
I had a problem with the radio initially and BananaHobby was unavailable for support after five requests. They get a failing grade for sure.
In my experience, this model is a waste of money.
(Disclosure: This is only my second model. My first one is also a foam park flyer - ParkZone Trojan. By comparison, it's a Cadillac!)
