RCU Forums - View Single Post - Help! Which RTF to get?
Old 04-23-2009 | 10:02 AM
mickvk
Default RE: Help! Which RTF to get?
Do you mind if I ask you a noob question: How do you secure the prop (which has hex insets on each side) with the two M3 nuts included? I guessed that I should install one nut, push the prop on using the hex inset, then add a washer and the final nut. Is that right?
