RE: G23 carburetor question
The pulse port will be visible on the engine side of the carb, through the carb spacer block, gaskets, and then in the intake port shoulder on the cylinder. All need to be lined up, without the gaskets partially covering the port...etc, in order for it to get the appropriate pulse from the crankcase to pump gas.
