RE: Nomadio React 2.4GHz Radio
I believe my biggest problem was trying to use my Sensor on my Window Vista PC. I tried it on my other XP PC and it seemed to work ok. Now my only problem is the trigger has zero response and when I turn the wheel, it turns on the throttle. I have tried every setting to correct it and no go. All of my software is up to date. Oh yea, when I plug in the receiver to the base of the Sensor, the PC says it can't locate it. I have tried turning it off and on etc. to no avail. I purchased the Sensor from ebay and it is not officially registered with Nomadio. Is that the problem?[>:]
