RE: Does down thrust push a jet down or up?
It depends where the turbine is mounted of course, but in the case of your Velox, down thrust will help push the nose DOWN. The Velox has a natural tendancy to want to climb at higher throttle settings. The stock mount is not set-up for straight and level at all speeds.
