RE: Does down thrust push a jet down or up?
if it is for your velox
this is what i recomend :
mount in the front of the mounting clamp about 10mm this will give about 4 degrees downthrust.
at higher speeds you will notice that it will fly strait , and flying inverted with no pushing the elevator.
