RCU Forums - View Single Post - YS 120 not running right after rebuild
Old 04-23-2009 | 04:59 PM
dditch's Avatar
dditch
Default RE: YS 120 not running right after rebuild
I flushed out the carb w/ fuel and tried again.
still the same.
I used byron 30% heli fuel.
I also wondered if I put the throttle arm on right. So I loosened it and rotated it 180 degrees and tried agian. same thing if not worse.
Here is a photo of about idle to 1/4 throttle
Is this right or should I rotate it 180 degrees back where it was?
