Engine Set Up- on the ground/in the air
Hey Slim..
You're really tapping this group for all it's worth hey? <GGG>
You're a good man Charlie Brown. Keep asking questions! There's more to learn than any person could gather in 5 lifetimes!
Here's a handy "rule of thumb" propeller load comparison formula that I've used for years....works well.
** Prop Diameter (in,cm) x 2 + Pitch (in,cm)
Example: A 10-6 prop would yield a load of:
10(2) + 6 = 26
an 11-4 prop would yield...
11(2) + 4 = 26.
Both props approximately load the engine the same (flight performance would be noticeably different).
It's a handy method of determining if you're increasing/decreasing the physical load on the engine.
Have fun!!!
