ORIGINAL: jeffk464
Ok, I'm working on putting my exi together but have a question about mounting the servos. I'm taking them off my belt cp which has a thick plastic frame. On the esky they were just mounted with sheet metal screws, do you install them the same way on the metal frame exi? It doesn't seem like there is that much frame for the screw to bite into.
NO....in the EXI kit, there should be some plastic NUTS...they're small and black in color. You MUST put a nut on each screw. I have a tiny set of needle nose pliers I use to hold the nuts while tighting the screws. It's the worst part of putting the EXI-450 together....installing servos.
