ORIGINAL: diceco
AMAZING YOU START YOUR MAGNETO EQUIPPED RYOBI BY HAND!!!!! I was never able to do that, not even close, which is part of the reason I went for the electronic ignition!
Say andrew66. I would jump at the chance to get a stock magnito system that I could hand start. Would you be willing to give us the particulars of your motor such as what vintage is it and what weedie it originally came from and maybe some numbers off the coil and flywheel unit you have. If anyone else is able to hand start their stock Ryobi please speak up with the same info.
Maybe too someone has already figured this out. Please speak up if so.
Thanks, diceco
