RE: Throttle curve
Ditto what Jake and w8ye said. To get the throttle curve with the servo you make it so at low throttle the servo arm is moving more across the plane than for and aft, that way you get lots of servo rotation with little throttle movement, then you get a lot of throttle movement as the arm is moving forward. The low speed is critical on the throttle, from 2/3 to full is much less so.
