Any way to get Hitec servo's to rotate opposite direction?
You have more than enough radio! I fly JR but I think the setup should be similar. Set up a 100% mix of channel 5 to your gear channel then reverse the direction for channel 5 and set the end points to avoid servo stall.
On JR I set a -100% mix - that should work without reversal.
Jim
