Any way to get Hitec servo's to rotate opposite direction?
What is your channel set currently - 3 channel + gear or 4 channel +gear ? If 3 channel + gear I'm not sure it will work using rudder for aux gear because the tx already controls rudder with left stick... That mix with rudder will probably result in interaction between the two. I guess I was thinking four channel plane with 6 channel rx. Might have to go with another solution or try a 6 channel rx.
Jim
