Hello Everyone,
I am new to the site and I just wanted to get an opinion. I have flown few gliders, and slow park planes. I prefer electric planes at the moment, since I do not see many beginner to beginner/novice gas powered planes. I have a plane in mind, the Global Wattage Cessna 180 EP Park Flyer RTF 24.5". Here is some information I have received from,
http://www3.towerhobbies.com/cgi-bin...?&I=LXGDW6&P=0 Also I do live next to a flying field for planes and helicopters, so when the weather starts to warm up I will get more information from there.
Please post any comments regarding my question. Like I said I do have “SOME” flying experience.
This is the electric powered, ready-to-fly
Global Wattage Cessna 180 Trainer Airplane.
For beginning modeler/fliers.
FEATURES: Foam fuselage, wing and tail section (white in color)
Ready to fly, just charge the battery, attach the wing and tail
section, install the prop and you are ready to fly
6-cell 2/3 AAA, 300mAh NiMH battery with unique connector
150mAh AC wall charger (charges battery in 2.5 hours)
Cirrus DPR-4FM transmitter with receiver and 2 CS-09 nano servos
(radio system in on 27MHz and has a charging jack)
7amp Electronic Speed Control with auto-cutoff (speed control has
proportional control and a fuselage mounted momentary switch)
1" (25.4mm) foam main wheels with pre-bent wire landing gear
Two 4.25" (108mm) diameter props with foam spinner (pitch not listed)
Pre-installed 180 size motor
Plastic tail skid
Pre-applied decals
INCLUDES: Fuselage, wing, tail sections, two props, foam main wheels, pre-bent
main landing gear, 4-channel transmitter (model has control of
throttle, rudder & elevator), pre-installed receiver, pre-installed
servos, pre-installed ESC, rubber bands for wing mounting, battery
charger and instruction manual.
REQUIRES: Eight AA size batteries for the transmitter
SPECS: Wingspan: 24.5" (132mm)
Wing area: 116 sq. in (7.49 sq. dm.)
Wing loading: 7.45 oz/sq. ft. (22.73 g/sq dm)
Length: 17" (432mm)
Weight: 6oz (170 grams)
RCFanatic101
