RE: Does a flat wing always need ailerons?
I think you should build the plane however you want. If you decide to go with 3 channels you will want dihedral. If you decide you want a plane with no dihedral, you will want ailerons. I could probably come up with an engineering explanation for you and Gene but I am too tired to think about it right now.
