ORIGINAL: Alliot
Thank you skyking for the link. That was what I did, and the performance was better. I didn't touch anything else on that flybar. You don't really see the difference until you fly the quark outside. But, there is also a pro and con for this setting, especially for new quark owners, so be careful. They should start with the stock set up first.
Also, I will appreciate if someone gives me a quick info on the hovering speed as I mentioned earlier.
Alliot: the RPM LED (ligth) should be on as you fly, correct RPM will influence and affect more the tail corles motor than the main engine (heat wise) touch it after flight with LED on or of. I burnt a corless after 13 months on my second Quark, Tim at MRC (Hirobos rep in US) said it was the first since they started selling the Quark over here. So take off watch for the light (see manual) land and adjust until it's on.
