RE: Does a flat wing always need ailerons?
What I am doing is a major bash on a Micro Telemaster. Wider wing panels by about 1" with sheeting and ailerons, fuselage 1/4" wider and 1" longer, stab about 10% bigger, slide in wing panels. Maybe other things during the build. If anyone is interested I am considering doing a build thread in case i need suggestions, ideas, opinions.
QUESTION: How does one determine how much throw ailerons should have on a plane that originally did not have ailerons?
QUESTION: Will the throws change on a stab that is made 10% bigger?
