RCU Forums - View Single Post - Using dual channels for ailerons/elevators
Old 04-28-2009 | 08:02 AM
jetmech05
Default RE: Using dual channels for ailerons/elevators
If this isn't your first gasser forgive me.....now you will see why I asked you about the engine....for safety sake please use an optic kill switch with your gas engine.....there will be no direct electrical connection between the ignition and the airplane, plus if you loose system power the engine will shut off.....and it is a way to manually shut off the engine.....Y ailerons and use the open channel for a choke servo....you'll be glad you did.....good flyin to ya
Oh by the way my Mom's back yard boarders I-29 just past the Faron Rd. overpass in St. Joe.
