RCU Forums - View Single Post - GB Extra 300
Thread: GB Extra 300
Old 04-28-2009 | 10:29 AM
Gray Beard
My Feedback: (-1)
Default RE: GB Extra 300
Just so you know, the weak spot in this plane is the fuse doubler that runs from just in front of the wing. These days we tend to run larger engines then when the kit was designed and I have seen several of them have the fuse break just in front of the wing and fall off, one of mine included. If you look at it there isn't much holding on the nose section from the wing forward. This is a good time to add a 1/8 light ply doubler over there doubler. Pick up your engine and cowl then give it some thought, the picture in your minds eye will come to you right away.
