RCU Forums - View Single Post - Using dual channels for ailerons/elevators
Old 04-28-2009 | 02:18 PM
spitfire66's Avatar
spitfire66
Default RE: Using dual channels for ailerons/elevators
So you would use a y-harness to connect 4 ailerons to 1 channel? I have thought about this quite a bit and the only reason I want to use 2 channels is so I can maintain symmetry and have adjustments to each set of ailerons. If 4 to 1 is safe I will have no problem doing it, I am just looking for advice and rules of thumb with these bigger planes. Thanks.
